Clicking sound turned into a grinding sound. - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2009, 04:44 AM
I have a 98 V6 camaro..a while back at low speeds I heard a clicking sound coming from the front left area of the car (rotor, wheel area) Now I dont hear the clicking anymore it sounds more like a grinding, at any speed..it sounds like the wheel is rubbing the fender but its not. Is there a bearing in the wheel hub or what can it be? Also maybe I should mention its louder when I accelerate...even on the freeway if it coasts its not as loud but once I hit the gas crrrrr...thanks guys.
Old 11-19-2009, 06:49 AM
sqzbox's Avatar
My pipes are my music
Wheel bearing or worn out brake pads gouging the brake rotor. Either way, you need to get it checked out. The lonnger you wait, the more it's going to cost to get it fixed.
Old 11-19-2009, 12:00 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The brake pads are equipped w/a metal tab that is meant to contact the rotor when the pads are worn to the "time to replace them" point.
This metal tab (if that's the 'problem') can put out a pretty good amount of noise- noise that to the untrained ear would make you stop and find out the problem.
You can easily check for this by removing the wheel and looking at the pads to see if the tab's rubbing. If that's it, the tab can be bent back from the rotor to buy you some time to get new pads on it. Have the rotors checked for thickness and run-out while you're at it.
The next time you hear the noise- if you bend the tab- will be the pad's steel backing tearing hell out of the rotor, so don't put off doing the brakes too long.
Anytime you jack the car up and remove the wheel, you must have another form of support for the vehicle like a jack stand before you put any part of your body under the car! Just the car's jack alone is very unstable and can kill you. Don't use cement blocks, wood, etc., either.
BE SAFE!!!
« 54chev | 49 olds »
Grinding sound when turning steering wheel? dhomsey General Rodding Tech 11 12-14-2006 01:18 PM
New engine, horrible grinding sound....anyone want to make a bet TurboS10 Engine 23 10-31-2004 06:56 PM
steering clicking when turned left and right BanditT/A Suspension - Brakes - Steering 13 11-30-2003 06:35 PM
FE 460 ?'s Low oil press, clicking sound. brotherbob Engine 4 10-06-2003 10:53 PM
Weird grinding sound 1992 Transport Van Engine 4 04-25-2003 09:09 PM
