Clip Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-23-2007, 05:02 PM
Clip Question
New to the forum, but have been following for your really good topics and answers.
Need suggestions on which later model Chevy clip would be the best and easiest to swap into my 46 Chevy 1/2 ton to replace the stock solid front (suicide axle) and assembly.
Old 11-23-2007, 05:18 PM
life is a temporary assignment
Just finished a 58 Chevy truck with a 70's model nova clip,Worked out very nice.Also did a 48 Chevy with a 79 model camaro,It also worked out very nice.the nova had the rear steer.Hope this helps.I have some pics of the 58 in my album.
Old 11-23-2007, 06:23 PM
Wiki Edits: 49
The Nova is probably a better choice since its a bit narrower than the Camaro, however you still may need to narrow the crossmember a bit to get the track correct for a 46.
Old 11-23-2007, 06:34 PM
Centerline is right about the nova being narrower .The 68 to 72 nova is 60 inch's flange to flange.
The 76 to 80 camaro is 61.5 inch's flange to flange.
Old 11-24-2007, 09:11 AM
Clip
I will look for a Nova front clip and do some measuring.
Thank you for all your help
383 stroker 73monte Engine 13 05-11-2016 11:17 AM
supercharger.... 73monte Engine 16 07-24-2010 10:27 AM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 01:20 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 10:25 AM
front clip retrofit beetle9 Suspension - Brakes - Steering 1 01-09-2002 02:24 PM
