Clockwork Indicator and Hot rod - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2008, 08:58 PM
I am wanting to know what is a clockwork indicator that was used in the old days of traditional hot rods. A description and/or picture would be great. From all reports these were self cancelling based on time/ duration.
Thanks
Ford91a
Old 05-22-2008, 06:14 AM
With over 30 views and not a single response ... I think we may have a failure to communicate here. I understand you are from Australia and may be using a different term for what you what to know.
" Clockwork Indicator "
Old 05-22-2008, 06:57 AM
malc's Avatar
Living At The Speed Of Life
Could it be one of these ???
I suppose the Australians use the term "indicator" as do the British for turn signal.
Old 05-22-2008, 08:47 AM
OK ... that's reasonable
On a good many of the older vehicles I have owned ... they had something like this.
Found on eBay
http://cgi.ebay.com/ebaymotors/Chrom...QQcmdZViewItem
Old 06-04-2008, 03:28 PM
Clockwork turn signal switch
Correct Australia indicator switch = turn signal switch.
Example provided is brilliant. However, pictures of steering column in my car do not show any fixtures/fittings to the column. I gather it is a switch that is dash mounted.
Any further examples would be greatly appreciated.
cheers
ford91a
Old 06-04-2008, 03:31 PM
Wiki Edits: 31
cheers
ford91a
clamps to the column
