clogged exhaust symptoms
I have dual exhaust flowmaster. One side is 10 years old and the other is 2 years old. Buick 401 , 65 Riviera. No heat riser flap.
What are the symptoms of a clogged side? I have exhaust coming out of both sides and it difficult to tell if its even. |
About the only way the exhaust system con get plugged up, is part of the muffler come lose and get lodged someplace. Or if you have a double thickness exhaust pipe, the inner layer can collapse, I`ve seen this happen numerous times on original equipment exhaust systems.
you should hear a air rushing sound or a whistling sound,and a noticeable loss of power. If you suspect an obstruction, take one side at a time loose, and see if it runs any better. HTH Good Luck Troy
