Your no gas problem could very well be inside the tank if Ford used the gas strainer (some call these parts : Socks) at the end of the pickup tube like Chevy did in 1955/56/57 and I'm sure beyond.
A cheap fix if you really feel it's the gas line, but some length of steel line and run it from the tank to the engine compartment. Any parts store sells stell line just for these situations. There's also the gas hose like Summit & Jeg's sell that you could run along the frame and replace your existing gas line. |
FWIW, the quick fix I've attempted so far because I actually had an hour I could spare by sleeping less was to take an air hose with nozzle and try to blow pressurized air into the fuel line (at the carb attachment) and into the fuel filler, neither of which made a difference.
I really need to take some time to disconnect the hose at the fuel pump to see if fuel comes out so I know if the blockage is downstream of the fuel pump or otherwise. |
Pull the line between electric pump and fuel tank...
and blow a little compressed air in thru the line to backflush any crud off the sock. You should hear air bubbling up from the filler neck. Use a steel inline filter to put the line back together, to prevent any debris from getting to the pump. You should have gas coming out of the pump by now when it's switched on. If not then either the pump is bad or it's not drawing a prime, maybe a leaky rubber hose atop the tank. Take it back apart at the new filter and drop a short piece of rubber line from that filter into a small gas can and see if the pump will now draw fuel. If so replace the lines to the tank as there is a leak, if not the pump is bad.
The Kustomsledd did this to me once, the tank sock was plugged up. Shooting some air back thru it blew it off the end of the steel line in the tank, where it remained until I pulled the tank and cut out the trunk floor for a new 25 gallon Doc-fabbed tank. |
Line Problems
I had the same problem with my original flat head 6 that was in my truck before it was pulled, All of a sudden, no fuel. Electric pump was pounding away, but nothing comming out. I took my air hose and blew air back into the tank, got the crud out of it. It worked for a little while. Then the pump failed. I pulled the motor and that's the way its been for a while. I agree, if you can free the clog, then run a filter before the pump to capture any debris. Great idea guys!
| Aluminum welding made easy and cheap! | daimon1054 | General Rodding Tech | 17 | 03-19-2007 07:34 PM |
| anybody ever have a pesky fuel leak? military fix | spinn | Hotrodding Basics | 5 | 07-04-2006 12:13 PM |
| 60-degree v6 fuel system issues. | ChevelleSS_LS6 | Engine | 0 | 05-22-2006 09:38 AM |
| Charging system info............... | poncho62 | Electrical | 11 | 11-26-2005 08:53 PM |
| 80' model Vette Fuel Tank, How do I fix a leak? | 9.8sec. Hemi | General Rodding Tech | 8 | 05-16-2003 06:30 AM |
