Closed Chamber Pistons With Open Chamber Heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2008, 05:41 AM
I Am Building A 427 For My 67 Camaro. 454 Block Gm Steel 427 Crank Beck Stage 3 Rods Trw 2239f Forged Pistons. I Am Using Gm Open Chamber Heads Wich Will Give Me 10.7 To 1 Compression. I Have Heard Of Piston Clearance Issues With Closed Chamber Pistons And Open Chamber Heads. If I Use A Thick Head Gasket Fel Pro 1017-2 .051 , Do I Have To Worry About This. It Will Also Lower My Compression A Little Which Is Good But I Dont Know How Much.
Old 03-30-2008, 07:17 AM
Closed chamber pistons ... do NOT hit the open chambered heads ... BUT open chambered pistons will hit closed chambered heads
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 03:50 PM
Cleaning Heads & Pistons DTL504 Engine 2 11-09-2003 06:13 PM
Open or Closed Chamber Heads? lakecityg Engine 1 06-26-2003 08:00 PM
Open or Closed? MI2600 Engine 7 06-13-2003 03:59 PM
Heads, and Open vs Closed Chambers... BigBlockBabe Engine 1 04-07-2003 04:58 PM
