closed/open ratio
Hello. Im more of an engine person, I know next to nothing about transmitions and rear ends. I just know the basics. Could someone please tell me the difference in a closed ratio gears and open ratios? And which is better for a 450hp daily driver. Thank you much.
An open rear is one that does not have a posi/locking unit in it. The wheel with the least traction gets the power.
Posi units give the rear end the ability to put power to both wheels.;
Ontario Rodders |
Poncho is correct. To elaborate a little.... you can drop the "ratio" from the term since the actual gear ratio has nothing to do with whether or not the rear end is open or "closed". You can have the same ratio in an open or posi rear end. The difference is as Poncho described. The "closed" or Posi rear transmits power to both rear wheels where the open transmits power only to the the wheel with the least traction which is usually the passenger's side. For a 450 hp daily driver I would definitely suggest a posi rear. Otherwise you'll have a lot of problems getting that power to the pavement.
Centerlline |
the thought I came up with is perhaps he was talking about close or wide ratio manual trannys?
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Centerline |
me too
To the orginial poster, This term is used mainly in the muncie transmission world. They made 2 different ratio transmissions ( excluding the 63 to 65 models) The 66 to 74 M20's were 2.52 / 1.88 / 1.46 / 1.00 All M21 and M22's were 2.02 / 1.64 / 1.28 / 1.00 The debate on what trans is better / stronger can go on for days. It usually comes down to a preference. Neither will give a huge benifit from the performance standpoint.... but needs to be matched to the rest of the combo and driving style... Keith |
Thank you all for the replies. Sorta funny tho, I was asking about the transmitions...but now that yall did post about rear ends, i remembered I was going to ask something about that eventually. Hah, thanks, and take care.
