cloudy brake fluid - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-30-2011, 08:29 PM
cloudy brake fluid
my 73 vette (manual brakes) has a brake issue. all of a sudden the pedal goes down. so i bleed the brake and sure enough there was air. after words the pedal was stiff and would brake fantastic. but after a couple days back to no braKES. there is no leaks anywhere. fluid is always top of. but its cloudy!!! so i flushed the fluid by opening the valves on the caliper the adding new fluid. and bleeding again. but same porblem. then i replace the master cylinder (bench bleed) and same thing. replace it with again and same thing all over again!!!! any suggestion !!???
Old 10-30-2011, 10:59 PM
Captain Obvious
if you replaced the caliper twice then you know that its probably not that. I would search better for a leak or maybe even a bad bleeder? ( ive seen it) put cardboard under the car to make sure its not leaking anywhere.
Old 10-31-2011, 09:18 AM
i havnt replaced the calipers, its the master cylinder i have replaced twice. could it be the proportioning valve??? how could the bleeder be bad???? there is absolutly no leaks from anywhere the brake system ie lines, calipers, master cylinder.....
Old 10-31-2011, 08:29 PM
Cape Cod Bob's Avatar
I have a similar problem. All my parts are new. I have a little brake fluid showing up at the prop valve. At the back where there is a little rubber cap covering some kinda valve. I don't lose hardly any fluid but the brakes slowly get air in the line and I end up double pumping.Its getting to be a real pain and I want to get another NEW prop vale . I will choose amnother maker. Good luck.
ps... putting paper or cardboard to check for leaks will probably not show much as most of the braking is done when moving down the road.
Old 10-31-2011, 09:06 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If there's any water in the system, the heat produced at the caliper can cause this water to vaporize, and that results in air in the system and a soft pedal.
Old 11-01-2011, 08:13 AM
capecodbob-i think the prop valve might be our problem. although maybe hick101 is on to something bout the bad bleeder. might replace both front bleeders first and see if that does the trick.
water in line theory might also work but i have flushed the entire brake system by opening one valve bleeder at a time and just pumping the brakes till the master cylinder goes empty. the fill it and on to the next caliper till i flush all 4. i drive for a couple days then NO BRAKES. i do another normal bleed and after a few days back to NO BRAKES. also the fluid get really cloudy to the point that eventually it turns black.
Old 11-01-2011, 09:39 AM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Originally Posted by OMARS67
capecodbob
First off, you should never bleed the brakes until the reservoir goes empty, because then you are pumping air back in the brake system. Always refill the reservoir before it gets to less than 1/4" of fluid. Secondly, the fluid turning black tells me that the fluid is getting very hot and burnt. I would check and make sure that you don't have a caliper sticking or the rod on the master cylinder missadjusted not allowing the master cylinder piston to return completely.
Old 11-04-2011, 08:42 AM
SO A COUPLE days ago i replace the two front valve bleeders with new speed bleeders and its braking perfect!!!!! who would have know valve bleeders can go bad.
Old 11-04-2011, 08:45 AM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
Glad that it worked out for you
Old 11-04-2011, 11:12 AM
Captain Obvious
glad to see you tried it out and didnt just think me a fool
Brake Fluid dot 3 4 or 5 How do I tell what's in there now? dirtinla Suspension - Brakes - Steering 12 06-20-2009 04:53 PM
Where's my brake fluid going?? STATUTORY GRAPE Suspension - Brakes - Steering 7 05-22-2008 06:24 PM
brake fluid rally4x4racer Hotrodders' Lounge 1 12-15-2004 04:54 AM
Brake fluid gottaluvchevelles Suspension - Brakes - Steering 5 11-13-2004 05:39 PM
brake fluid wally Suspension - Brakes - Steering 3 07-11-2003 03:54 PM
