cloudy clear problem >>.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2007, 09:32 AM
I am a newbie at shooting clear I have a panel off a street bike that i am trying to clear i messed it up when i tried to shoot it the other day im using the transtar hi gloss clear over black omni base i have a 60 gal commpressor with a dessicant filter at the gun. the gun is a gravity feed with a1.3 tip i mixed the clear properly as per ins. i shot the panel first wet pass looked good i waited 1-2 min then shot again ran out of clear went to mix some more 4 min later came back to it shot it again then i noticed looked like thousands of tiny little microscopic air bubbles in the clear waited for that coat to dry 1-2 min than shot the 3rd coat and same thing happend it is a little rough and looked cloudy help!!!!!!!!!
Old 07-14-2007, 10:04 AM
Solvent pop, you have trapped solvents. Black and other dark colors are the worst for this. You need to sand the clear with 600 and let it set in the sun for a few days, then shoot another coat of color and allow it to flash off real good before applying more clear. You will have more luck with a slower reducer designed for use in hot temperatures and also a slower curing clear- this allows the products to stay wet longer so the solvents can evaporate out. Hope this makes sense. Do a search on solvent pop and you'll likely find all the information I missed. Bob
Let that basecoat flash off for an hour or more before applying clear, if you rush it you'll trap solvent.
Old 07-14-2007, 08:36 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Same applies to time between clear coats.
1-2 min is no where near long enough for it as well. Probly the reason it popped on the second clear app.
I wet an area off the panel as I'm clearing nd use it for a touch test spot.
tacky is good,goo is bad. Depending on the clear product and how wet you sprayed, it can be as little as 15 min to 1/2 hr between coats.
Old 07-15-2007, 09:46 AM
I get it now, I thought it was moisture in the line thanks guys!!!!!!!
Which PPG clear system to use? hgufrin Body - Exterior 19 02-19-2009 11:09 PM
blower idle rpm problem Ratoflic Engine 7 12-01-2008 04:31 AM
Enamel Paint and clear cutsupreme Body - Exterior 55 10-20-2006 04:00 AM
Can I respray clear on top of clear that has dried if I sand it.. makaveli200369 Body - Exterior 5 07-02-2006 09:12 AM
Yargh, carbureator problem is driving me nuts (but not my car!) caustic meatloaf Engine 12 05-21-2006 01:41 PM
