Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cloyes 9 key Timing Set
Old 02-16-2012, 01:04 AM
hobby28 hobby28 is offline
I Degreed the cam and it came in at a 100 degree intake centerline and the cam card calls for a 102. So i retarded the timing set 2 degrees, but when i checked it again it came in at 104. I placed the crank gear on the r2 keyway and lined the cam gear up with the r2 on the outer markings of the crank gear. Am I doing something wrong with the timing set?
