-   -   Cloyes 9 key Timing Set (http://www.hotrodders.com/forum/cloyes-9-key-timing-set-214781.html)
hobby28 02-16-2012 01:04 AM
I Degreed the cam and it came in at a 100 degree intake centerline and the cam card calls for a 102. So i retarded the timing set 2 degrees, but when i checked it again it came in at 104. I placed the crank gear on the r2 keyway and lined the cam gear up with the r2 on the outer markings of the crank gear. Am I doing something wrong with the timing set?
stich626 02-16-2012 02:13 AM
remember the crank goes 720 degrees for every 360 cam degrees.
hobby28 02-16-2012 04:27 AM
So does that mean i am aligning it wrong on the timing set? Do you install the crank gear at r2 and line the marks up at 0?
