Cloyes 9 key Timing Set - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2012, 01:04 AM
I Degreed the cam and it came in at a 100 degree intake centerline and the cam card calls for a 102. So i retarded the timing set 2 degrees, but when i checked it again it came in at 104. I placed the crank gear on the r2 keyway and lined the cam gear up with the r2 on the outer markings of the crank gear. Am I doing something wrong with the timing set?
Old 02-16-2012, 02:13 AM
stich626's Avatar
gearheadslife
Last journal entry: The TwoTonShu #10
remember the crank goes 720 degrees for every 360 cam degrees.
Old 02-16-2012, 04:27 AM
So does that mean i am aligning it wrong on the timing set? Do you install the crank gear at r2 and line the marks up at 0?
Help with Cloyes 2 piece timing cover Landshark928 Engine 4 10-16-2011 09:18 PM
Cloyes two pc timing chain cover? Bowtie man Hotrodding Basics 0 08-27-2011 09:04 PM
Cloyes timing set? awoodman Engine 9 10-17-2007 09:04 PM
Cloyes timing product failure Tim Feeley Introduce Yourself 1 11-10-2004 07:05 PM
Cloyes timing chain 53vicky Hotrodders' Lounge 1 06-03-2002 07:20 PM
