Cloyes timing chain - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-03-2002, 07:05 AM
53vicky's Avatar
Question Cloyes timing chain
I purchased a Cloyes true roller timing chain set. One gear has 3 keys all shaped differently.
Does any one know what the degrees of these 3 key areas are ? I installed it without degreeing it and the motor rpms slowly and tops out at around 4000 rpms.
Thanks
Old 06-03-2002, 07:20 PM
E.T. divided by $ spent= Speed
Post
One is 4deg. retard,one is strait up and one is 4deg. advanced. If its winding out early you probably have it advanced. If I remember correct for every 4deg. cam advance the entire RPM range will be 500rpm lower. Is it winding out around 500rpm less than it should? Good Luck
