Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cloyes timing set?
Old 10-17-2007, 07:30 PM
Rick WI Rick WI is offline
Align with the zero mark, that should index the cam per the cam card. The other keyways will advance or retard the cam, which is not what you want to do if you speced your cam correctly.
We use a sleeve over the snout and tap the gear on.
