Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cloyes timing set?
Old 10-17-2007, 07:08 PM
brian0605's Avatar
brian0605 brian0605 is offline
mostly confused
Last journal entry:
if memory serves me correctly the keyway on the crank will be around the 1 or 2 oclock position at tdc.use the center keyway on the gear. someone please correct me if i'm wrong. Brian
