Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cloyes timing set?
Old 10-17-2007, 08:36 PM
Hot Rod Hooligan Hot Rod Hooligan is offline
Find tdc on #1 cyl.
The timing mark on the crank sprocket should be on top
install the cam sprocket properly
Line up the 2 timing marks so they are facing each other
Crank timing mark on the very center at the top, and cam timing mark on the very center at the bottom of their respective sprockets.
install the timing chain.
