CLOYES true roller chain set - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2004, 11:50 AM
bullheimer's Avatar
NEVER use credit cards!
does this beeotch come with gears that are thicker than stock so that my harmonic balancer wont go on as far as it used to? i swear to god it did. or is this just a figment of my imagination like so many other things, mainly the concept that i vaguely know what i'm doing.
Old 06-06-2004, 08:30 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Hmm, never really looked. I have run several of the cloyes sets and had no problem. I dont think there could be a difference because I have never had a belt alignment problem.
Chris
Old 06-06-2004, 09:17 PM
Meangreen's Avatar
I am running a cloyes tru roller timing set and havent experienced what you are talking about. They seemed original concerning their thickness.
Old 06-07-2004, 12:35 AM
59vette's Avatar
I installed a CLOYES set on my old C1 corvette engine.
The belt was perfectly aligned when I was finished!
A couple of things that I took care of:
1: NO burrs on the shaft around locating pin, -won't bind when pressed on
2: NO burrs on the end stop for the gear, correctly seated
3: Turned the gear the right way around with the chamfer towards the engine.
4: Made sure everything was cleaned properly
Just my .02
Regards
Bjarne
