cloys timming cover - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2007, 08:30 PM
cloys timming cover
When using a cloys timing cover, I found that you have to clearance the cam bolt retainer center, so that the end play thrust button will fit through and work against the cam.
Also I took a little aluminum from the inside of the cover to clear the cam bolts. O well , thats the life of a mechanic.
Valce cover Oil leak problem / PCV system question hotrodf1 Engine 7 05-01-2007 02:44 PM
edelbrock AL timing cover 68chevelle_ss Engine 1 03-29-2004 10:15 PM
Car Cover Recommendations? EricTopless68 Camaro Body - Exterior 1 03-19-2004 09:58 AM
Timing Chain cover '67Pony Engine 2 09-08-2003 11:39 AM
Timming Angie Engine 2 11-08-2002 06:21 PM
