clunk - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2006, 12:49 AM
clunk
hey i have a 1989 camaro rs and there is a wierd clunk when i give it to much gas off the line does anyone have any answers so i can check it out so i kinda know what im looking for?
Old 03-19-2006, 01:21 AM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
clunk
Pretty good chance its a u-joint. Check them out for sloppiness. Even if they don't move they may be frozen until you apply enough force ("when i give it to much gas off the line") to break them lose and you get your clunk.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 03-19-2006, 03:53 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
Could be Motor mounts...
Pop the hood, (Look for air cleaner marks rubbing on the hood) start it up, put the brakes on, and put it in gear and torque stand it a little..
IF the engine rises more than a half inch, you need mounts.
Do the same in reverse.
If those are good, Crawl under the car, with a floor jack, and find a suitable spot on the transmission and jack it up a little, if it rises, it's bad..
Loose or broken shocks will thump around when the drive train is torqued. Also the bushings on them could be shot slamming the shock around under sudden throttle.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Rearend clunk briz Transmission - Rearend 8 09-11-2005 08:14 PM
Clunk, Driveline Slack redneckgmc Transmission - Rearend 3 11-10-2004 10:54 PM
clunk noise on drum brakes jartzh Suspension - Brakes - Steering 13 11-04-2004 04:26 PM
slight clunk/ shift kit install Q's HARVICKx29 Transmission - Rearend 2 02-16-2004 10:51 PM
9" rear end clunk or excessive play eric302 Transmission - Rearend 9 07-08-2003 01:31 PM
