clunk in Ididit steering column - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2008, 07:23 PM
I installed an Ididit tilt steering column in my '63 Vette. I vehicle has 200 miles on it and there is a 'clunk' when I turn the wheel. It appears to be coming from the housing area of the tilt (I assume there is a knuckle in the column.)
Everything seems tight, the steering box the tie rods, etc. This is a power steering car.
Has any one had this problem?
Thanks
Old 06-01-2008, 07:29 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Got any upward pressure on the shaft? Loosen the bolts off that mount it to the dash and then try it. Put the wheel in a neutral position also.
Old 06-01-2008, 09:23 PM
powerrodsmike's Avatar
Wiki Edits: 161
Does the clunk occur at the same point in the rotation of the wheel? Does the clunk occur at all tilt positions? or just one? Did this just start? or has it been since you installed the column?
The knuckle in that tilt column is a plastic ball with slots, each shaft has a "C" shaped yoke which engages the slots. There is a U shaped spring that is supposed to keep the joint tight, but it would have to be in a serious groove in order for it to clunk.
There is a pair of bearings on the upper shaft that are preloaded with a spring under the key lock collar, if those bearings are loose it could make a sound as well.
If the main housing is loose on the lower housing,(the pressed in pivot pins are loose, or the knuckle ws machined wrong, or it is an early Ididit column that still used USED parts... it will rock up and down when you turn the steering wheel, that could make a clunking sound.,
If the clunking sound is accompanied by a tight spot, and occurs at the same place twice in every rotation, you could have a binding U joint..
Just a few suggestions....
Mikey
BE different....ACT normal.
Old 06-02-2008, 09:40 AM
302 Z28's Avatar
All of the above suggestions except for one more. Are you using a support bearing? Some of the cheaper ones allow too much slack in the lower steering column extension shafts.
Vince
Old 06-02-2008, 11:06 AM
Irelands child's Avatar
......and one more - are any universals timed correctly? These have to be set up the same way as the driveshaft universals. That includes the one in the column to the rag or universal joint.
I suggest you call IDIDIT - I haven't had any problems but I have talked to the owners several times at shows and there doesn't seem to be an BS to them.
Irelands child
Old 06-02-2008, 04:37 PM
Thanks for all the suggestions. I finally called Ididit and they are shipping a new column out today. Hopefully, it will work and I can go on the Power Tour.
Thanks
Old 06-04-2008, 08:41 AM
Welder Series' ***** Guy
Ken and Jane are great people to deal with.
Old 06-04-2008, 06:14 PM
Spoke to them at Goodguys Del Mar.......spent way too much of their time with my questions. I was impressed, and will use their columns in my cars. I was impressed to hear him say that if you ever have a problem with one of his columns, send it back and they will rebuild it and ship it back, without an invoice! That really got my attention.
Old 06-05-2008, 06:44 AM
If I have a chance this weekend at NSRA York I'll tell them they have some good "press" here.
Dave W
Irelands child
'39 ford steering column and wheel jim williams Suspension - Brakes - Steering 5 07-01-2010 10:38 PM
Steering column switch 82 Dodge 150 Bryan59EC Electrical 6 07-05-2008 09:07 AM
Steering Column Install Quarter Flash Suspension - Brakes - Steering 3 05-10-2007 12:36 PM
Steering Column for 1971 Chevrolet C/10 glayman Suspension - Brakes - Steering 13 02-24-2007 02:08 PM
Ididit Shorty Steering Column Question seadog Suspension - Brakes - Steering 2 05-10-2006 04:47 AM
