Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - clunk noise on drum brakes
Old 11-04-2004, 04:26 PM
Pony's Avatar
Pony Pony is offline
To check the rears you will have to remove the brake drum, rotate the axle to line up the axcess hole in the axle with each mounting nut/bolt and tighten. Check them all as they can look tight even when not. The front backing plates are mounted to the spindles.
