clunking feeling on right turns - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-04-2010, 02:34 PM
71 dodge dart
at 50mph and faster
when i turn right slightly at this speed
gets worse the more right i turn the wheels
i feel a clunking feeling at the drivers side floor board when this happens
doesnt happen when going straight
doesnt happen when turning left
looked under the front end and everything seems tight. everything is new and has maybe 800 miles on it
Old 12-04-2010, 03:01 PM
LATECH's Avatar
The exhaust and the "K" member comes to mind.Check the K member bolts and look for a spot that the exhaust may be hitting the underbody. Maybe the upper control arm bushing is bad.
Old 12-04-2010, 04:30 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
What shape are the torque box's in ? You might want to check the torque box's also and the subframe bushings. JMO
Cole
Old 12-04-2010, 10:38 PM
maybe a ball joint??? my bushings are all new and polyurethane. torque boxes are not rusted.
Old 12-05-2010, 08:39 AM
T-bucket23's Avatar
Wiki Edits: 26
Check for a broken engine or transmission mount. Fan hitting on shroud etc. Centrifugal force can to strange things to rotating parts when turning corners.
Chet
Old 12-05-2010, 10:09 AM
eloc431962's Avatar
Wiki Edits: 37
Yes it could very well be a ball joint. i would check the ball joints and the mounts also like stated. Are all the bushings new in the front end ? Does it have a sway bar on it ? And i have seen a bad/broken shock do this also.
And is it just a sound or do you feel something giving /moving when it happens ?
Cole
Old 12-06-2010, 03:44 AM
its not just a sound, i feel it in the floor board up on the firewall behind the brake pedal. my car has no carpet so i can really feel it. it has no sway bars.
Old 12-06-2010, 04:16 AM
Maybe you could seek some advice from somewhere infested with people familiar with these cars?
Old 12-06-2010, 01:46 PM
Hmmm... double post, sorry...
67 Camaro wheel turns in when jacked up bigiron40 Suspension - Brakes - Steering 13 05-12-2014 08:27 AM
97 Civic 'tick tick tick' on turns ChevelleSS_LS6 Suspension - Brakes - Steering 2 08-24-2009 10:11 AM
Feeling body work tip. MARTINSR Body - Exterior 8 05-29-2006 11:39 AM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
rebuilt motor turns over slow... Trav Engine 3 05-26-2004 06:20 PM
