Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Which clutch?
Thread: Which clutch?
Old 12-27-2012, 04:03 PM
V8&4spd V8&4spd is offline
Last journal entry: Paint
If you have a late 80s block it might be a 1 piece seal block. The way to go with that would be the lite weight flywheel made by GM. Your engine will rev quicker and the flywheel is already balanced for either a 305 or 350 1 piece seal engine. They use a 10.5 inch clutch. If you have a bellhousing for the big flywheel, you can still use the smaller flywheel, the difference will be the starter. Most of the mini starters are made for either size fllywheel, they just use different mounting holes on the block.
