Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Which clutch?
Thread: Which clutch?
Old 12-27-2012, 05:11 PM
31ROC's Avatar
31ROC 31ROC is offline
Originally Posted by V8&4spd View Post
If you have a late 80s block it might be a 1 piece seal block. The way to go with that would be the lite weight flywheel made by GM. Your engine will rev quicker and the flywheel is already balanced for either a 305 or 350 1 piece seal engine. They use a 10.5 inch clutch. If you have a bellhousing for the big flywheel, you can still use the smaller flywheel, the difference will be the starter. Most of the mini starters are made for either size fllywheel, they just use different mounting holes on the block.
So let me see if I got this right....
Buy a 10 1/2 inch clutch?
Buy a stock GM flywheel for 1 piece seal block?
I dont have a bellhousing yet, but was considering the Mcleod 8633...
The starter I have now which fits in the current 700R4 will not fit the above items?
