Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Which clutch?
Thread: Which clutch?
Old 12-27-2012, 06:26 PM
V8&4spd V8&4spd is offline
Last journal entry: Paint
First you need to find out if your block is a 1 piece seal. You can look the block number up to find out. They make a big flywheel and small flywheel for both the 1 piece seal and 2 piece seal engines. They also make a small flexplate for automatic transmissions. If you already have the small flexplate than you can use the same starter you have now on the small flywheel. You can throw a lot of aftermarket parts on there but do you really need them? Steel scatershields, big flywheels and clutchs will just add weight to your car.
