Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Which clutch?
Thread: Which clutch?
  #42 (permalink)
Old 01-04-2013, 11:56 AM
V8&4spd V8&4spd is offline
Last journal entry: Paint
It does not matter if the block came from a car or truck. You can use either the big flywheel or small flywheel for a 2 piece seal engine as long as you have the right flywheels. The only difference will be the starter mounts on the block.
