Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Which clutch?
Thread: Which clutch?
  #43 (permalink)
Old 01-04-2013, 03:13 PM
31ROC's Avatar
31ROC 31ROC is offline
Originally Posted by V8&4spd View Post
It does not matter if the block came from a car or truck. You can use either the big flywheel or small flywheel for a 2 piece seal engine as long as you have the right flywheels. The only difference will be the starter mounts on the block.
Well...i dont wanna change my current starter which is mounted on the block.....so which flywheel should I be buying if flexplate which was removed was 153 tooth?
