Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Which clutch?
Thread: Which clutch?
  #44 (permalink)
Old 01-04-2013, 03:24 PM
V8&4spd V8&4spd is offline
Last journal entry: It Will Work
Both the big flywheel and small flywheel starters are mounted on the block, they just use different mounting holes. If you have a mini starter it might be drilled for both flywheels. The small flywheel or big flywheel use is up to you. The small flywheel aluminum bell housings are easier to find and they usally want more money for the big flywheel bellhousings. If you go to a scatter shield and big flywheel you are adding weight to the car verses the small flywheel and aluminum bellhousing.
