Which clutch? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-27-2012, 06:00 PM
Last journal entry: Paint
It's your money, you can spend it as you wish. It does not mater if you are racing the car. A lite weight flywheel will help your engine rev quicker. A 2piece seal engine is balanced different than a 1 piece seal engine. You can't interchange the flywheels between a 1 piece and 2 piece seal engine, it will throw the balance off. All those parts can be found easy without going aftermarket. GM had to put a warranty on the parts when the car was new. What kind of warranty do those aftermarket parts carry?
  #17 (permalink)
Old 12-27-2012, 06:05 PM
A 1 piece seal engine and a 2 piece seal engine will have different block numbers. Once you have the block number you can look up the info without tearing it all down to find out what you have.
  #18 (permalink)
31ROC's Avatar
I am not understanding....but i DO appreciate everyone's input.
I am just looking for advice on what size, brand clutch and flywheel to buy that would be appropriate and fit my car? I dont care if they are aftermarket or GM parts, just need to know what is correct and fit?
Thanks again.....
  #19 (permalink)
Old 12-27-2012, 06:11 PM
If it were mine, I would use GM parts since they made a zillion of them. As far as clutches a lot of the parts are just reboxed. I have bought new clutch disc off Ebay for as cheap as $10 and it was a Luk. I have had a lot of different brands and when you compare most of them they are the same.
  #20 (permalink)
Old 12-27-2012, 06:57 PM
1971BB427's Avatar
You don't have to worry about weight, so you really don't need to spend the extra for a lightweight flywheel. I'd get a regular steel flywheel, and get a 10.5" also. I'm pretty sure you can use the same starter, but you can easily count the teeth on your flexplate and compare to the 10.5" flywheel to be certain. Most 10.5" flywheels will be 168 tooth, but you can buy them for 153 tooth, so be sure it's a 168 to match your present starter.
Your car probably wont weigh over 2500 lbs max, so I'd go the 10.5" Hays. I'd also go with a regular organic/carbon or iron/organic clutch material. The iron/organic is a bit better, but a bit more money also. For your setup, I'd go diaphram type pressure plate and not 3 finger, as they are a bit smoother, and less grabby.
Ram makes a good unit also, and is a little cheaper priced than a Hays. I think your Muncie will take a 26 spline clutch disc, so make sure you get the correct spline count. Be certain to tell the seller it's for a SBC from 1980, so you get the right pressure plate.
  #21 (permalink)
Old 12-28-2012, 03:55 AM
31ROC's Avatar
Thanks guys!
  #22 (permalink)
Old 12-28-2012, 09:00 AM
vinniekq2's Avatar
buy a scatter shield,steel flywheel,11 inch diaphram hayes or mccleod,NOT center force.All I use and zero problems with more power and heavier car.
  #23 (permalink)
Old 12-28-2012, 09:39 AM
gearheadslife's Avatar
MentalMuffinMan
it the engine is stock and the valvecovers are the center bolt type
it's a 1 piece rear seal..
depending who you talk to, they changed in 86-87
in a light car, with traction issues
a 10.5" will be fine, if you do clutch dumps, I'd get a scatter sheild over a bellhousing..
under the car with the inspection cover off the trans(if it's even there) you'll be able to see if the engine is 1 piece rear main seal.. with a flashlight.. you see alum bewteen flexplate and engine it's 1 piece
  #24 (permalink)
Old 12-28-2012, 10:53 AM
31ROC's Avatar
OK.....I'll be at it tomorrow AM....thanks again.
  #25 (permalink)
Old 12-28-2012, 11:04 AM
If it were me; and you feel this apprehensive, Id call up Pace Performance directly. They're a GM dealership I believe as well as selling Hi Perf parts. They sell complete kits. It may not be the cheapest way around the barn, but it'll all work together, assuming you give them the right tooth count/ starter and 1 or 2 piece R.M.S Dont use the online helper thing...its useless, CALL them. Boom. done. If you have an issue, they'll answer the phone, and they have a return policy. Problem solved. Get it runnin!
  #26 (permalink)
Old 12-28-2012, 11:34 AM
31ROC's Avatar
Not apprehensive at all.....just looking for advice to what parts would fit, work properly, for my circumstance....
  #27 (permalink)
Old 12-28-2012, 01:44 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
X2^ I have been on the phone with McLeod engineers and have found them to be knowledgable and helpful. Their products have proved bulletproof for me.
http://www.mcleodracing.com/info/?id=3044
  #28 (permalink)
Old 12-29-2012, 06:26 PM
31ROC's Avatar
OK guys,,,,here's what I got...removed 700R4 today, attached are pics of crankshaft and flexplate....this should help you all determining what to buy for a clutch and flywheel.....I believe it is 1 piece seal so that should help!
ID:	70203   Click image for larger version
ID:	70204   Click image for larger version
  #29 (permalink)
Old 12-30-2012, 01:57 PM
31ROC's Avatar
I am leaning towards the "RAM" either 10 1/2 or 11 inch clutch set....
  #30 (permalink)
Old 12-30-2012, 02:13 PM
1971BB427's Avatar
The Ram clutch kits seem to be very reasonably priced. Everybody carries them, but I haven't used one yet. I think I'd give it a shot also, if I was going to a stick.
one clutch to many willyb1 Transmission - Rearend 11 04-02-2010 07:02 AM
clutch help onenew32 General Rodding Tech 2 07-05-2007 10:57 AM
10 !/2 clutch or 11 inch clutch retired 56 Transmission - Rearend 8 03-26-2007 06:52 PM
Clutch help 79transam Transmission - Rearend 3 12-19-2004 11:15 PM
Lakewood Clutch fork clip broke/angle of clutch fork 70bird Transmission - Rearend 3 04-23-2004 07:04 PM
