Clutch - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2002, 04:03 PM
Post Clutch
I am the proud owner of a 5 window 28 Ford coupe. The car came with a 283 and 4 speed. The problem is their is no clutch or brake linkage. Does anyone know the best/easiest/cheapest way to install brake/clutch pedals and linkage? Thanks for the help. <img src="confused.gif" border="0">
Old 09-01-2002, 05:51 PM
Talking
In the old days we used a double (side by side) cylinder from a Chevy 1/2 ton. Early 60's. Mounted it on the firewall with swinging petals from the pickup. Used the Chevy V8 bell housing from the truck too. They were hydraulic. This way we got a master cylinder for the brakes and one for the clutch.
That was then. Now I would find a Turbo 350 to replace the 4 speed. Buy a petal kit from Speedway or somebody and put the master cylinder under the floor. Do your self a favor and use a master cylinder from 70 and up. Dual cylinder. Lots safer.
Old 09-02-2002, 12:44 PM
Post
Thanks for the input. It's good food for thought. What do you think about mounting the clutch pedal on the same shaft as the brake(under the floor) and hook it up to the clutch via a hydraulic throwout bearing?
Old 09-02-2002, 06:22 PM
Talking
[quote]Originally posted by fred56:
<strong>Thanks for the input. It's good food for thought. What do you think about mounting the clutch pedal on the same shaft as the brake(under the floor) and hook it up to the clutch via a hydraulic throwout bearing?</strong><hr></blockquote>
It would work. Some late model Chevy bellhousings are hydraulic I am told.
