clutch - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2006, 11:57 AM
clutch
I need to know what clutch to use in my chevelle , the last clutch I used was a borg&beck 12" Mcleod. It slipped at high rpm .like 4500 rpm and up. My trans first gear is 3.27:1, rear end ratio is 3.50:1, 26" tall tire.
Old 01-30-2006, 02:34 PM
joe350s10's Avatar
Bigger is better
what size motor?
How many horsepower?
what tranny are you running?
Old 01-30-2006, 05:27 PM
HP and trans
560 hp @the crank, richmond 6 speed.
Clutch problems on 66 Mercury onebadmerc Transmission - Rearend 21 09-23-2005 03:21 PM
Clutch preload? RB401 Transmission - Rearend 0 08-03-2005 09:26 PM
Lakewood Clutch fork clip broke/angle of clutch fork 70bird Transmission - Rearend 3 04-23-2004 07:04 PM
Need Help w/ Clutch Chatter-2002 TA WS6 Josey Wales Transmission - Rearend 2 09-20-2003 07:59 PM
clutch linkage!!? chevyelc81 Transmission - Rearend 11 08-01-2002 06:46 AM
