clutch adjustment - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2005, 07:13 PM
clutch adjustment
I am new to manual transmissions, I have a 4 speed Borg Warner in a 48 Chevy PU, when I get on it hard in any gear the clutch slips. I need help on exactly how to adjust. Thanks
Old 08-19-2005, 07:28 PM
T-bucket23's Avatar
Wiki Edits: 26
Clutch Adjustment
Sounds like you need to make the clutch rod shorter. You want to have 1/4 to 1/2 inch of play in the pedal. If you already have free play and it is still slipping, you need a new clutch. If you keep driving it you will burn it up if you havent already. Adjusting the rod shorter will also move the engagement point closer to the floor.
Hope this helps
Clutch problems on 66 Mercury onebadmerc Transmission - Rearend 21 09-23-2005 03:21 PM
Clutch preload? RB401 Transmission - Rearend 0 08-03-2005 09:26 PM
clutch adjustment trouble Niapym Transmission - Rearend 5 06-20-2005 03:10 AM
Lakewood Clutch fork clip broke/angle of clutch fork 70bird Transmission - Rearend 3 04-23-2004 07:04 PM
Clutch (free pedal) Adjustment 66chevy2ss Transmission - Rearend 5 05-03-2003 06:29 PM
