Clutch Chatter - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2006, 01:20 PM
super_silent's Avatar
Clutch Chatter
Hello everyone,
I recently bought a 68 RS/SS with a 4 speed trans. When I start off in 1st gear the clutch chatters like crazy till it gets going. Also the pedal grabs a little on the high side rather than half way down. I contacted the previous owner and he told me the car has new clutch in it. Is there anything I can do to correct this ? and also is there a way to adjust the clutch to grab lower ?
Thanks in advance.
Old 09-18-2006, 02:36 PM
Originally Posted by super_silent
Hello everyone,
Thanks in advance.
Some years ago (10-12) I had problems with Rayloc clutches from Napa, you could surface flywheel and it would rattle your teeth when you started out. Also caught about the top of pedal travel.
Had rayloc rep at my shop a couple times, He quit Rayloc a short time later, I just quit using them, or if a customer really wanted one put in, I would tell them we would install, but if it had to be removed under warranty, they would have to take it elsewhere, as Rayloc would not pay the full installation price that we charged.
I started using LUK, they were new units and not that expensive,compared to rebuilt, also they didn't even want a core back.
Old 09-18-2006, 04:11 PM
1Fast65Elky's Avatar
Left Nut, Right Nut....Squish!
Last time I had some chatter, it was caused by loose bellhousing bolts...
You might wanna check and see if theyre all tight.
Old 09-18-2006, 04:48 PM
T-bucket23's Avatar
Wiki Edits: 26
Make sure everything is tight and the rear main isnt leaking onto the clutch.
Improper installation or a bad flywheel can also cause issues.
Old 09-18-2006, 05:10 PM
Guy Hiltz's Avatar
Clutch Chatter
As posted above LUK make the finest clutches available,a buddy of mine owns a tranny shop and that is all he will use.Also dont be misled into buying a Centerforce clutch,they are farmed out to other clutch manufacturers,I know for a fact that some are made by LUK,who knows who else makes them!Another thing that could be causing your chatter is the flywheel itself,it might need re-surfacing or replacrment.
Old 09-18-2006, 07:44 PM
Years ago I had an 84 Z28 that I had the clutch replaced on. A buddy of mine ran the shop and told me that LUK were the best clutches so that's what they installed and I had the same chatter problem as this one. They changed the clutch on that car 3 times before the chatter was gone.
They called the Rep in to look at it and I believe the last one they put it was not a LUK.
« fords | tv bracket »
Busted Clutch chrisflock Transmission - Rearend 1 04-15-2006 03:08 PM
Clutch problems on 66 Mercury onebadmerc Transmission - Rearend 21 09-23-2005 03:21 PM
Clutch preload? RB401 Transmission - Rearend 0 08-03-2005 09:26 PM
Lakewood Clutch fork clip broke/angle of clutch fork 70bird Transmission - Rearend 3 04-23-2004 07:04 PM
Clutch chatter zman48 Transmission - Rearend 5 10-13-2003 12:02 PM
