Clutch engagement at top of pedel - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2013, 06:09 PM
65ELCMO's Avatar
Just put a new engine in a 65 El Camino. The car was not running when I got it. I used the clutch and throwout bearing that came out of it.
It had a Saganaw 4 speed in it and I chainged to a Muncie.
The clutch seems to work OK but I have 3 inches of pedel travel before engagement starts. It is just at the top of the pedel travel.
Any Ideas or is this just something I have to live with?
Old 04-23-2013, 07:02 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
I'm kind of confused with the pedal travel part. Just so you know, you should not have to depress the pedal to the floor to disengage the clutch and engagement should not be at the very top of the pedal travel. You should be able to feel when the throwout bearing starts to touch the pressure plate by the feel of the pedal, you should have about 1" of free pedal before that happens. This ensures that the throwout bearing is not turning all the time. It sounds like you just need to do some linkage adjustment.
Old 04-24-2013, 06:00 PM
65ELCMO's Avatar
I will check that. I just got the car out of storage. I moved and only drove it a few miles. Now I have it home to debug. Thanks
98 s10 5spd hard to engage in gear, very early clutch engagement... 1986c10 Transmission - Rearend 4 01-31-2013 06:32 PM
cutting out when i let off or mid pedel rambler454 Engine 1 04-14-2012 08:46 PM
hard pedel slow stop campracing Suspension - Brakes - Steering 10 12-22-2009 08:09 AM
39 chev PU hanging pedel stea Suspension - Brakes - Steering 6 05-31-2005 11:12 AM
Brake pedel weak RickB1B Suspension - Brakes - Steering 21 02-12-2005 05:18 PM
