Clutch fight auto trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-04-2010, 10:35 PM
clutchflight trans.
My next door neighbor in somerset KY used to build them. his name is don Caulder. he had a a 63 ply. with a 413 wedge he used 727 trans out of 68 or 69 big ply. etc you get the picture. the baddest trans I ever seen. electric shift. drop the clutch coming off the line !!!!!!!!!!!!!!!!! then hit 2 and then 3 it was all over . this was in the late 60's early 70's look him up. he has the answer to every question you could possibly have.
Old 12-05-2010, 07:54 AM
BOBCRMAN@aol.com's Avatar
I was at an auction recently. There was two clutch turbo's there. One was missing the belhousing. They went for $80.00 each...
Old 12-05-2010, 08:09 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
See they are really in demand, hard to find..... they must be good... the secret speed trick..
Old 12-05-2010, 02:33 PM
ericnova72's Avatar
More for Less Racer
Modern torque converter technology has killed the demand for these, a good stall converter will walk all over a clutch-auto trans becuase of the converters torque multiplication. Todays modern horsepower is also more than the small automatic input shaft can stand for long, the clutch-auto(either 927 or TH400)just isn't reliable.
Old 12-05-2010, 04:00 PM
WDCreech's Avatar
Grumpy Old Goat Herder
I don't know if a high stall converter, alone, will match a clutch auto, but a transbrake and a converter matched to your engines torque peak will. A t-brake and high stall converter is just as, if not more violent than a clutch, and almost as hard on parts.
Bill
