Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Clutch/Flywheel Recommendation?
Old 11-26-2008, 01:12 AM
carsavvycook's Avatar
carsavvycook carsavvycook is offline
My 2 cents worth
Wiki Edits: 3
Has the vehicle been changed from it's stock gear ratio yet? This will need to be done prior to putting in a performance, or racing clutch. If not, you will have a tremendous 'chatter' taking off in first gear.
This information is found in small print, in the installation paperwork supplied with the clutch you ordered.
