Clutch/Flywheel Recommendation? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-24-2008, 09:13 AM
mrdreex's Avatar
I have a 383 SBC that will be pushing roughly 550-575HP at the crank, and am in need of a clutch. I am somewhat uninformed in this area, and I could use some recommendations on what kind of clutch/flywheel setup I should run.
I have done a bit of research, and have come to the conclusion for the type of driving I will be doing, a billet steel flywheel (~15-20lbs) or an aluminum will fit my needs. I have also been recommended to use a Centerforce clutch. Which clutch should I run from them? Which one will survive 550 HP? Should I go with a Centerforce flywheel as well? What works for you? Since my 383 is internally balanced, should I be looking at pressure plates that are NOT counterweight assisted?
This will not be a daily driver. It will be driven mostly on weekends, and may see the track once everything is finished and ready. When it is driven, I plan on spinning it to around 6,500 - 7,000 RPM's and shifting somewhere around there. The tranny is a Borg Warner Super T-10, and it's a gen. 1 SBC with a 2-piece rear main.
Thanks.
Old 11-26-2008, 02:12 AM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
Has the vehicle been changed from it's stock gear ratio yet? This will need to be done prior to putting in a performance, or racing clutch. If not, you will have a tremendous 'chatter' taking off in first gear.
This information is found in small print, in the installation paperwork supplied with the clutch you ordered.
Timing Light Recommendation RoadKing96 Engine 28 02-26-2008 01:30 PM
Timing Light Recommendation RoadKing96 Garage - Tools 2 02-14-2008 03:56 PM
Need recommendation... page2171 Body - Exterior 0 03-30-2007 07:45 PM
Budget muffler recommendation fearsomefairmont General Rodding Tech 3 06-26-2005 12:11 PM
Budget muffler recommendation fearsomefairmont General Rodding Tech 2 06-24-2005 01:08 PM
