Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Clutch grabs hard when cold
Old 10-01-2012, 07:52 AM
timothale timothale is offline
Wiki Edits: 27
things to check
Did they install a new roller- ball bearing pilot or a bronze bushing ? bushings wear out too fast. are all the bellhousing bolts, trans bolts tight ?. Motor mounts Mid engine ? , Hanging by a front and the trans by the rear will cause clutch problems, propper gear lube in the trans?
