clutch hydraulic slave cylinder - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2005, 04:02 PM
I would like to know how to remove the hydraulic line from the slave on a 97 ranger 4x4 with internal slave
Old 12-31-2005, 05:17 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
if Im correct its all one piece and its only replaceable as a whole unit and you have to pull the trans out because its around the input shaft
..if Im right
SR66
"SlowRide66"
"Illegitimis non carborundum"
Old 12-31-2005, 10:25 PM
TechnTool's Avatar
OldSchool MotorHead
Two ways. One, use the tool tht OTC has made, or take 2 screwdrivers and gently depress the outter shell, while pushing in the line, then when the outter shell is all the way in, pull out the line. It's kind of a push in line, push in shell, pull out line. Be gentle, take your time. If you have knarled the fitting, then use the OTC tool. this is whaqt the tool looks like, goto your local parts store and pick one up.
http://www.aktoolsandequipment.com/i...D&ProdID=27946
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
clutch slave cylinder 1963duce100 Transmission - Rearend 2 07-26-2005 08:13 AM
clutch slave cyl vs hydraulic throwout brg BOOKS4CARS Transmission - Rearend 19 01-27-2005 12:15 PM
How to bleed clutch slave cylinder? shockers69 Transmission - Rearend 5 12-18-2003 08:47 PM
clutch slave cylinder mount wally Transmission - Rearend 1 03-04-2002 09:20 AM
