Clutch linkage help on '59 Chev PU - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-07-2008, 08:34 PM
Zimmo's Avatar
A long time ago when I installed a 455 Olds & TH 400 into my '59 pickup, I needed to cut out the crossmember that had the origional clutch pivot on it. I'd like to reinstall a manual trans again (but this time behind the B/B olds), & I need to fabricate the linkage somehow.
Has anyone done this? I'm thinking about getting an Olds M/T Z bar, & welding in a bracket so it matches up to the pivot ball on the block. I was thinking about installing a hyd setup, but that me be even more work & more costly.
Thx in advance
Old 12-08-2008, 06:12 AM
have you the flywheel ?
i get them from jegs , centerforce brand , i paid like $192 for new one .
as for hydraulic , hard part be adapting the thing to bell housing , unless you go blow proof .
Old 12-08-2008, 05:12 PM
Zimmo's Avatar
Yeah, I have everything for the conversion except for the manual trans. I was looking at the option of installing a TKO-600, but $3800 for the kit is too much $$
http://www.5speedtransmissions.com/
I do like the extenal slave cyl bellhousing kit tho
http://www.5speedtransmissions.com/hydclutchpkg.html
Old 12-08-2008, 06:43 PM
Is your 455 Olds crankshaft drilled for a pilot bearing for a manual trans ????
As far as I know if the Olds engine came with an automatic trans the crank wasn't drilled for a manual trans pilot bearing .
Gene
Old 12-08-2008, 06:52 PM
Zimmo's Avatar
Hey thx. Yep, the short block I'm building came out of a '71 442 M/T. The "N" crank is drilled & the block is bossed with the z-bar pivot ball.
I'm really looking forward to having an MT behind this torque monster. I'm building it for torque, & I'm hoping to get halfway desent gas mileage out of it too (my Vista Cruiser would routinely get 17 MPG on the highway with a 455!!)
Gotta love old tech & no smog
Need Help ! - Chevelle / Olds 442 Clutch Linkage MARSHMAN 442 General Rodding Tech 1 09-10-2007 08:53 PM
Clutch linkage problems-Centerforce??? baddbob Transmission - Rearend 1 03-09-2007 08:50 AM
Studebaker hawk clutch linkage webbest Transmission - Rearend 0 12-11-2005 08:19 PM
48 Chev PU door latches AaronT Body - Exterior 8 01-24-2003 11:29 AM
IFS on '51 Chev PU Berns Suspension - Brakes - Steering 0 10-01-2001 01:20 PM
