Clutch master cylinder - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2009, 08:52 PM
ASE Master Tech
Does anyone know where I can find information on what size bore and stroke a clutch master cylinder is for an 07 silverado. I bought a used 5 speed to swap into my 72 truck. The stock master cylinder just installs with a quarter turn in the firewall and prob won't work very well. I was thinking of going with a bolt in aftermarket of some type just need to find sizes to fit. Thanks for any help!
Old 07-13-2009, 04:04 PM
ASE Master Tech
Any suggestions or ideas where to look anyone?????? according to gm parts catalog the original should fit 02-07 1/2ton. the trans is an nv3500. anyone swap one of these in?
Bleeding a Clutch master & slave Bryan59EC Transmission - Rearend 5 08-03-2006 06:16 PM
HELP ASAP - 77 T/A Master Cylinder and Prop. Valve Question Torx Suspension - Brakes - Steering 1 06-26-2006 01:52 AM
39 Deluxe master cylinder adapter? MM in NM Suspension - Brakes - Steering 4 09-30-2005 03:42 PM
Help with continuing master cylinder problem chris57 Suspension - Brakes - Steering 3 09-30-2003 02:35 PM
Stang master cylinder Old Crow Suspension - Brakes - Steering 3 06-10-2002 12:40 PM
