clutch pedal on 32 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2010, 04:11 PM
clutch pedal on 32
Has anybody installed the "X" member from CHASSIS ENGINEERING on a 32 Ford frame and found out you can't install a cluch pedal because it hits the lowe portion of the X member when depressed? If anybody has any ideas or pictures, it would be of great help. I don't want to use hanging pedals.
If somebody makes a kit that fits or has used a particular brand, please chime in and pictures are more than welcomed. Thanks,,,,,,,,,,,,
Ernie
Old 05-16-2010, 10:05 PM
Bump!
Anybody? Questions?
Old 05-17-2010, 08:16 AM
302 Z28's Avatar
Could you possibly use a hydraulic slave and master clutch system? Have you called Chassis Engineering about the problem?
Vince
Old 05-17-2010, 08:37 AM
powerrodsmike's Avatar
Wiki Edits: 161
These guys have a bracket and pedal assembly that might work..
http://www.progressiveautomotive.com/brake.htm
These guys sell pedals and you can build your own bracket.
http://www.est1946.com/brake_clutch_combo.aspx
Later, mikey
BE different....ACT normal.
Old 05-17-2010, 10:33 AM
I am using a hydrahulic clutch with slave cylinder. I also contacted Chassis Egineering and they said to go with an automatic tranny because they have heard from people like me with the same problem.
Seems to me when you depress the clutch pedal,,,,, the clutch arm hits the lower portion of the X frame. I would hate to cut the X member and make it weak, it also looks awsome now. Thanks guys and I appreciate your input.
Ernie
Old 05-17-2010, 11:33 AM
327NUT's Avatar
Yea now isn't that a hell of an answer from Chassis Eng ??? If they've heard from others you might think that they would do a little re-engineering and make a fix for the 3 pedal boys. Looks like you're going to have to do some fabrication, obviously I can't see the frame but can't you cut the interference piece or modify it and add a stiffener near it. Has to be some way to do it, remember the body will cover up the chassis so know one will see it anyhow....good luck.
Brake Pedal Placement PROBLEMS! artillerystevens Suspension - Brakes - Steering 10 12-23-2013 10:47 PM
How Much Pedal Travel redsdad Suspension - Brakes - Steering 5 08-29-2011 05:24 PM
htd clutch problem 2112jb Transmission - Rearend 2 02-16-2006 07:15 AM
56 Clutch Pedal Help isitdoneyet? Transmission - Rearend 4 12-08-2005 03:50 PM
Flathead Clutch Problems Hot Rod Bod Transmission - Rearend 9 08-22-2004 07:39 PM
