clutch pedal not returning to engaged position - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2011, 12:24 PM
i just installed a new motor in my chevy pickup which has a 4 speed standard shift transmission ..with the new motor i also installed a brand new oem flywheel and a dual friction centerforce clutch (which is designed to install on a stock flywheel application). i just started the motor last night for the first time .. when the old motor was in the truck the clutch pedal returned properly. however now when i press the clutch in . the pedal comes back up about two inches and just stays there . the resivroir is empty so im assuming it just has air in the line but wanted a second opinion. . thanks ,garland
Old 07-29-2011, 10:40 AM
S10xGN's Avatar
Gotta love a turbo!
Well, the obvious thing to do would be to refill the reservoir, bleed the system, and try again.
Russ
Old 07-30-2011, 11:50 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
X2, I would think the clutch isn't fully disengaging either, only releasing as far as it's returning.
Semper Fi
clutch pedal junkyard85 Transmission - Rearend 3 08-12-2010 01:53 AM
clutch pedal on 32 aztlanco General Rodding Tech 5 05-17-2010 12:33 PM
1932 brake pedal position homesimpsonr Suspension - Brakes - Steering 3 02-12-2008 04:06 PM
56 Clutch Pedal Help isitdoneyet? Transmission - Rearend 4 12-08-2005 04:50 PM
Brake pedal not returning? alf51chevy Suspension - Brakes - Steering 3 06-13-2005 04:33 PM
