clutch problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-03-2011, 05:10 PM
87fubar's Avatar
clutch problem
my friends 97 3.8l camaro's clutch to get it to release you gota put it all the way to the floor. I've try'd bleeding the clutch no change. i did notice after releasing the pressure i had to pump it couple times to feel any pressure.could this be a clutch master cylinder or slave problem i really hope its not a slave cylinder
Old 06-03-2011, 06:02 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
Either you have trapped air or the master is not sealing at the top of its travel, hence not displacing enough volume of fluid to give the slave the travel it needs to release the clutch properly/fully
Unless you have been working on the hydraulic system I would say its not air, most likely the master
Old 06-04-2011, 01:30 AM
87fubar's Avatar
we did have the quick connect at the slave cylinder disconnected when i connected it back had little air come out first time bleading the system
i blead the clutch couple times after but only fluid was coming out no air at any point
Hydraulic clutch problem? Jemerson86 Transmission - Rearend 7 08-30-2008 09:19 AM
Need Help With Clutch Problem On 97' Civic jordan2011 General Rodding Tech 4 03-21-2007 04:32 PM
htd clutch problem 2112jb Transmission - Rearend 2 02-16-2006 07:15 AM
CLutch problem deboner Introduce Yourself 1 10-21-2004 02:50 PM
'39 clutch problem Bills39Ford Transmission - Rearend 0 07-20-2002 09:37 AM
