Clutch problems
Got the 5 speed trans put in, new disc, pressure plate and throwout bearing. No matter how far i adjuct my clutch rod, i cant get my clutch to release. Any ideas as to what is wrong. I have installed about 100 clutches in my life time, and never had this happen. I put this s10 5 speed behind my 250 six banger, and use the Astro van 11" clutch disc. Need help bad.
Are you feeling any pressure at-all when trying to adjust it out ? You do have the disc on the right way i guess ? Could be the throw out bearing also. JMO
Wait is that a hyd clutch set-up? Cole |
Clutch problems
Clutch problems
Clutch problems
I cannot get my clutch to release. I have tried just about everything. It worked fine untill i installed the Astro 11" clutch disc to use with the 5 speed. I have had the trans out 3 times now, and cannot find the problem. Please someone help here. Anyone used the Astro 11" disc before with the S10 5 speed.
Sounds like the disk in in backwards or the throwout bearing angle is off. When you step on the clutch can you see the throwout bearing push the clutch fingers.
Artificial Intelligence is no match for Natural Stupidity Chet |
Since the only thing different is the Astro disc, I would suspect that to be the prob. Compare the old disc with the new Astro and note any dif. in hub design/dementions/thickness. Also check part No. to make sure you actually were given the correct disc.
I cannot get my clutch to release. I have tried just about everything. It worked fine untill i installed the Astro 11" clutch disc to use with the 5 speed. I have had the trans out 3 times now, and cannot find the problem. Please someone help here. Anyone used the Astro 11" disc before with the S10 5 speed. |
Clutch problems
I have checked that my clutch disc is in right, the pivot ball is lubed and lined up correct. I have found that the splines on the 5 speed output shaft do not come all the way back to the collar that the throwout bearing rides on. On my old trans they came all the way back. My 5 speed is 1" short on the splines coming back, and i think i am binding up on the clutch disc when i install the trans. The new disc is the same thickness, and like i said THE ONLY THING I CAN FIND IS THE SPLINES ON THE 5 SPEED DONT COME BACK FAR ENOUGH. tHIS MAY BE MY PROBLEM. i HAVE TALKED TO 3 DIFFERENT TRANS SHOPS, AND THEY HAVE NO IDEA WHAT IS CAUSING MY PROBLEM, BUT I THINK I NOW KNOW WHERE TO START. Will put the trans back in wed, and will let you all know if that was the problem. My arms are getting sore from lifting this trans so many times in this cold weather, but i will solve this problem. Thank you all for trying to help me out, you all inspire me, as you have so much knowledge. We will get this fixed, as i have to get my car back together, as my only one eye i have left is getting worse, its up to 20-100 now so i am now half blind in the only eye i have left, and i am building this car for my wife so she can ride in style in her 48 chevy Cream Puff. I will not give up.
That's right never give up. And yes let us know how it goes.
Cole |
Clutch problems
Well i got my clutch to work, after pulling the trans 4 times. The problem was the splines on the input shaft were different than my old 3 speed. The plines came all the way back to the collar for my throwout bearing, but on the 5 speed they were about 3/4" shorter. I took my clutch disc to the machine shop and had 3/16" cut back on the splines this kept the disc from binding up when i tried to release the clutch. This was all it needed and now my clutch works great. I used the Astro 11" disc, and with the 3/16 taken out it made my clutch release perfect. I also has to make a 1/8" spacer BETWEEN THE TRANS AND BELLHOUSING. No ONE COULD FIND THE PROBLEM AS I WAS PUTTING THIS BEHIND AN INLINE 6, WHICH IS DIFFERENT THAN A v8 OR v6. but I GOT I TO WORK JUST GREAT.You can see in the photo what i am taking about with the splines. I hope this will help someone else if they run into this problem. And they can contact me and i will walk them through this.
either way, im just happy for you on getting it working. |
X2 I'm glad you got it going also.
Cole |
| Busted Clutch | chrisflock | Transmission - Rearend | 1 | 04-15-2006 03:08 PM |
| Taurus SHO clutch issue... I know, big surprise... | ViperMonster800 | Transmission - Rearend | 3 | 04-04-2006 08:33 AM |
| Clutch problems! | Demondrive | Transmission - Rearend | 7 | 02-23-2006 09:11 AM |
| Borg Warner Shifting problems | Spiders | Transmission - Rearend | 17 | 12-28-2005 10:38 PM |
| clutch linkage!!? | chevyelc81 | Transmission - Rearend | 11 | 08-01-2002 06:46 AM |
