Try this. Have some one push the clutch petal in real slow while you are under the car and watch it. I have seen the flat pieces of metal peal away from the pivot shaft when the clutch is pushed. I have seen forks that are cracked flex when the petal is pushed. Its amazing how you wont even see the crack in the metal unless the clutch is pushed in. Just watch it and see if there is anything wrong.
