-   -   Clutch problems on 66 Mercury (http://www.hotrodders.com/forum/clutch-problems-66-mercury-67346.html)
onebadmerc 08-03-2005 10:41 AM
I need some input on some problems I am having with my clutch. Last year my clutch went out on my 66 Mercury Comet and I had a shop replace it. The new clutch then expired after 30 miles of use and the shop owner refused to do anything about it. My car then sat until just 2 days ago when I finally had enough time and money to fix it. The problem I am having is when I push in the clutch it hardly moves the fork and then the pedal sticks to the floor. This is the same problem I had with the Centerforce Clutch I just replaced. The shop who replaced it last year had to lengthen the clutch adjustment rod to just get the clutch to work. I bought a Ram Clutch to replace the Centerforce Clutch, this was the same clutch I used before the Centerforce Clutch. I did not have any problems with the Ram Clutch until it expired last year. Does anybody have any ideas, could there be something wrong with the mechanical clutch linkage or is something else wrong?
BTW, the clutch isn't slipping it just isnt engaging and the pedal isn't releasing.
broncoII88 08-03-2005 05:01 PM
Was the throwout bearing replaced with the new clutch? If it's real bad or installed on the fork wrong, it might be binding. That shop prolly used a cheap ***** clutch which was toast after a few miles. That sucks! :pain:
onebadmerc 08-03-2005 05:19 PM
The throwout bearing came with the Centerforce Clutch, it wasn't a bad or installed wrong. I am going to pull the fork boot this afternoon and check to make sure the thowout bearing on my new clutch didn't slip off the fork when I stabbed the tranny last night. The tranny went in pretty easy last night so I doubt this will be the case, but I am going to check it out anyway.
broncoII88 08-04-2005 08:44 PM
Since that shop dicked around with the clutch linkage :nono: , they prolly messed something up bad which is haunting you now. The cheap clutch that shop used I'M thinking was prolly the WRONG ONE. If they used the wrong one, then something might have screwed up the linkage/fork mechanism. :pain: :confused:
Eric Von Zipper 08-07-2005 11:31 AM
Start from the ground up.
Take it all down. Remove the flywheel, have it surfaced. replace the shaft bushing in the middle. If it is a bearing replace with bushing.
Next buy a 180 lb 8 spring HD clutch plate, and roller release bearing with grease fitting. (dont forget to grease it 2x a year)
Check to make sure the release bearing was not install backwards and the petal return spring move the petal freely when no hooked to the clutch fork.
Also check to see is the pivot rod between the petal assy and the release bearing fork isnt adjusted all the way out. If the wrong plate or bearing was installed, a way to compansate would be to crank it out, restructing the fork travel.
Also anyways post engine size, 3 or 4 speed and floor or 3 on the tree linkage
454me 08-07-2005 01:17 PM
Try this. Have some one push the clutch petal in real slow while you are under the car and watch it. I have seen the flat pieces of metal peal away from the pivot shaft when the clutch is pushed. I have seen forks that are cracked flex when the petal is pushed. Its amazing how you wont even see the crack in the metal unless the clutch is pushed in. Just watch it and see if there is anything wrong.
Fast Orange 08-07-2005 03:06 PM
I'm going to echo what 454 said-I had a Mustang 4 speed that did that as soon as I put in a performance clutch. I pulled down the linkage,welded and gusseted the pivot arm,beefed up the rods . The problem disappeared.
Check the nylon bushings on both ends of pivot arm-they add a lot of play when they're gone also.
Good Luck,George :cool:
onebadmerc 08-07-2005 09:42 PM
The clutch works fine, it is not slipping a bit at all, the pedal is just stuck on the floor and it wont adjust out. I had my girlfriend press on the clutch pedal as I was under the car and everything looked good. I pulled the dust boot off the fork and checked for movement of the throw out bearing and to see if anything was not right, everything was good there. I checked the pivot points and nylon bushings on the equalizer bar and everything is good. The last thing I checked was the rod coming off of the pedal assembly and the pedal return spring. The rod looks like it is coming out at a angle and the clutch return spring on the pedal assembly wont tension when the pedal is pushed. I went over to Ford Forum.com and somebody over there said that since my car was originally set up for a long style clutch that a diaphragm clutch wont work unless I get a weaker clutch pedal return spring. Is this true or is it a bunch of BS, I cannot find anything else wrong besides the pedal return spring and clutch rod. This is the second clutch that has been put in my car with the exact same problem. This is driving me nuts and I am about ready to say forget it and let it sit another year.
BTW, the engine is a 66 289 with a cast iron 28 spline 4 speed Borg Warner T10 out of a 65 Ford Fairlane Fairlane. The flywheel was resurfaced and the clutch is a 10" Ram for SB Ford.
454me 08-09-2005 09:15 PM
Well if it doesnt slip and the pedal is on the floor I would suspect the fork is off the ball inside the bell housing.
broncoII88 08-10-2005 06:12 PM
Are you sure that the friction disc is installed facing the right way? The center of the disc sticks out more on one side (flywheels side) If a disc is installed the wrong way it can bend when the clutch is worked, probably screwing the linkage/pedal action. :pain:
T-bucket23 08-19-2005 08:45 PM
Clutch
It seem to me that if you are seeing little to no movement of the fork and the pedal is stuck to the floor then you have a linkage problem. The clutch would return without a return spring. The return spring only holds the throw out off of the fingers so its not spinning all the time. I am assuming that this is a purely mechanical clutch linkage. It almost sounds like a hydrolic that needs to be bled. If teh disk was installed backwards then it would not engage at all period. If someone turned down the flywheel to much it will move it away from teh throh out bearing but that is a long shot. My guess is they monkeyed with the linkage more than they are admiting. When you said the clutch only lasted 30 miles. What was wrong with it. Was it slipping or was it that it would not disengauge. If it was slipping it was probable adjusted wrong and it will burn up real quick. If it wouldnt release my guess is the linkage broke or bent somewhere.
junkyardjeff 08-20-2005 10:46 PM
I had to replace the clutch return spring with a heavier one when the clutch in my 66 F250 was replaced with a diaphram style clutch,I would of liked to have the other style but thats what the parts store gave when the parts was ordered. Jeff
KULTULZ 08-21-2005 06:59 AM
Are you absolutely sure you have the correct pedal asm./pedal to bellcrank actuating rod and/or bellcrank? It sounds as if there is incorrect actuation of the bellcrank (due to incorrect/bent/out of alignment linkage) not allowing full release of the pressure plate.
Did the clutch asm. come with installation instructions? It used to be on GM applications that used these as stock (diaphram), whereas FORD used LONG or BORG-BECK style (finger actuated plate) that once installed, proper adjustment could only be made with an air gap measurement made between the disc and plate while fully depressed. If the linkage is not allowing full release, the pedal will hang on the floor or near to it.
Also heed the previous advice about a turned down flywheel. There are shims available to bring it back into the correct relationship with the clutch asm. The other poster that recommended reinforcing and gusseting linkage parts also has a good idea, especially on a race car. Have you checked the availability of a clutch cable conversion? It will rid you of all slop.
sel2real 08-21-2005 01:09 PM
i'm going with the clutch return spring theory, as i've had this happen to me on a car i changed the clutch from the long style to a diaphragm style. the "return" spring is more like a helper spring that has a break-over point to "help" the pedal go down after a certain point (which long-style clutch pressure plates needed!). since you went to a diaphragm-style, pedal effort is significantly reduced. in a car i went diaphragm-style to, the pedal would stay on the floor. removing the original return/helper spring and installing a VERY light spring to just get the pedal from resting on the pressure plate worked for me! in fact, this method has worked for me in 5 different cars! have had NO problems whatsoever in the last 12 years....
KULTULZ 08-21-2005 04:51 PM
:thumbup:
Very good point. The diaphram clutch does require a lot less of left leg pressure. I suppose that is why they have become so popular. I never liked the things because back in the sixties on a performance CHEV the diaphram plate would collapse on high RPM speed shifts. I guess they have overcome that problem. But you are correct in the spring strength helping to depress a finger style plate.
