Clutch problems 95 camaro 5 speed - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2004, 09:56 PM
I have problems. I cannot get shifter in any gear. Neutral only.Have had leaking slave cylinder . Add fluid every 2 weeks. Shifted good until today.Pedal still goes down as normal. Car is a 95 camaro,3.4, 5speed. Would like to know if it is clutch or slave unit or somthing else alltogether. thanks namdlo@fidnet.com
Old 06-22-2004, 10:39 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Slave is used up. Change the master while you are at it.
