Clutch Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-24-2006, 10:30 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Clutch Question
Does anybody know what the springs in the clutch disc are for? I've always wondered but never really know...
Old 09-25-2006, 04:35 AM
BOBCRMAN@aol.com's Avatar
They give the clutch a dampening/cushioning effect on engagement. As the disc is compressed against the flywheel, the springs are compressed a bit, till the drivetrain gains momentum.
If you ever drive anything with a solid center disc. The difference is very noticable.
Old 09-26-2006, 06:54 PM
It chatters to high heaven without them.
Old 09-26-2006, 09:45 PM
Blazin72's Avatar
Wiki Edits: 19
In what applications might you find a solid center disc and what (if anything) would beneficial about them? I don't think I've ever seen a solid centered disc.
Old 09-26-2006, 11:10 PM
youd probably find it more in dragracing where every little effort to reduce parasitic loss is important.maybe.
Old 09-27-2006, 04:56 AM
steve392's Avatar
just passin' thru
Last wiki edit: How to title a hot rod
Last journal entry: Willys is Finished!
Wiki Edits: 2
I am using a McLeod "Street-Twin" 2-disc clutch in my street rod, and the discs have no damper springs...I talked to Mcleod about this and was told that they weren't needed on the twin disc setup.
Go to page six of my project journal (when viewed from the beginning), and the last entry on that page will show a picture of the clutch along with the explanation that McLeod gave me. I don't have the car on the road yet to verify if what they say is correct.
Steve
Old 09-27-2006, 06:08 AM
Multi-disc units. Fork lifts. Tractors. Heavy duty truck/tractors,Old style drag cars. All have used solid disc clutches.
383 stroker 73monte Engine 13 05-11-2016 11:17 AM
supercharger.... 73monte Engine 16 07-24-2010 10:27 AM
Clutch on and off FirebirdFitzpatrick Transmission - Rearend 2 02-19-2005 11:43 PM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 01:20 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 10:25 AM
