Aluminum has about as much resistence to a clutch explosion as tissue paper..What we did in the old days was to make a pattern with poster board of a shape that surrounded the bell housing and then transfer that pattern to a piece of 1/4 inch steel which was cut to shape and then bent to conform to the shape of the bell housing. this piece is then attached by means of the bellhousing bolts to the back of the block. the scattershield should extend to the front of the trans and down far enough to deflect any debris from coming up through the floor boards and into the drivers feet and legs..
Now for sure I am not sure of where you can find someone with the fab skills to make one of these things as the skills needed are fast becoming obsolete. Sam
Advanced has a bell but it's also aluminum. Seems odd no one has a steel bell for the 4500, but I didn't look very hard. |
i used to hear of folks using scattershields on cars that expected to see extremely high RPMs, but most street performance vehicles did not use them. However, I did see a street-driven SS 396 Chevelle where the clutch blew up, and pieces of the it went straight up and through the hood. It definitely made you think.
Bruce |
There should be a cast iron version of the aluminum bell you now have, it would be stronger- and heavier, but if you have a hydraulic clutch the mounts wouldn't be there...
well i could fab up a home made setup, i have some 1/4" steel around and i have a small welder that would just barely weld it.
5300 is where i have the fuel cut set on this motor. but being that its in a mud truck, it lives around 4500rpm constantly so i thought it would be a good idea. iv seen a clutch explode on a jeep with a warmed over small block doing a truck pull. rpms weren't high but the clutch was slipping, i think the heat caused it to fail. what do you guys think about the blankets? that would be the easy route. |
| Clutch fan dead - new options | Torque454 | Engine | 12 | 03-09-2011 02:31 AM |
| Lakewood Scattershield | Steve karch | Transmission - Rearend | 3 | 02-19-2007 07:40 AM |
| Scattershield vs Bellhousing | mrl | Transmission - Rearend | 4 | 01-11-2007 06:33 PM |
| Ansen scattershield/clutch lever | new 32 roadster | Transmission - Rearend | 1 | 10-03-2005 10:25 PM |
| Lakewood Clutch fork clip broke/angle of clutch fork | 70bird | Transmission - Rearend | 3 | 04-23-2004 07:04 PM |
